[geos-devel] [GEOS] #1119: Buffer memory issue
geos-trac at osgeo.org
Thu Jun 3 14:40:12 PDT 2021
Reporter: kalenik | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.9.2
Component: Default | Version: 3.9.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by dbaston):
> Interesting. The OP says he encountered this in PostGIS - but wouldn't
PostGIS have set those handlers as well?
Yes. The problem seems to arise from the handlers that PostGIS is
registering with GEOS, not with GEOS itself.
> In any case, we really want to try and return an actual result, rather
than a crash or an error.
Yes, although it will always be possible to exhaust memory, so it's
important that the out-of-memory behavior not be a crash.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1119#comment:12>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
