[geos-devel] [GEOS] #1116: HeuristicOverlay debugging code enabled in release
geos-trac at osgeo.org
Thu Jun 24 14:19:14 PDT 2021
Reporter: dbaston | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.9.2
Component: Default | Version: 3.9.0
Severity: Unassigned | Resolution: fixed
Keywords: |
Changes (by Justin Bronn <justin.bronn@…>):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"c5f9a3ded8f3c2b6d87d6b74b2e95805d96d9b26/git" c5f9a3d/git]:
#!CommitTicketReference repository="git"
revision="c5f9a3ded8f3c2b6d87d6b74b2e95805d96d9b26"
Use `#if` instead of `#ifdef` macros for an already defined value, fixes
#1116.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1116#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
