[geos-devel] [GEOS] #1116: HeuristicOverlay debugging code enabled in release
geos-trac at osgeo.org
Thu Jun 24 14:31:18 PDT 2021
Reporter: dbaston | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.9.2
Component: Default | Version: 3.9.0
Severity: Unassigned | Resolution: fixed
Keywords: |
Comment (by Paul Ramsey <pramsey@…>):
In [changeset:"3fcdbcfe30d42f814ff00da49a195c8f2298186f/git" 3fcdbcf/git]:
#!CommitTicketReference repository="git"
revision="3fcdbcfe30d42f814ff00da49a195c8f2298186f"
Use `#if` instead of `#ifdef` macros for an already defined value, fixes
#1116.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1116#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
