[geos-devel] [GEOS] #1103: Target "tinyxml2" of type OBJECT_LIBRARY may not be linked into another target.
GEOS geos-trac at osgeo.org
Tue Mar 2 02:13:48 PST 2021
target.
 Reporter:  strk                   |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  3.9.2
Component:  Build/Install (cmake)  |     Version:  master
 Severity:  Critical               |  Resolution:
 Keywords:                         |
Changes (by strk):
 * priority:  major => blocker
Old description:
> $ git describe --tags
> 3.9.0beta2-239-g89886fb23
> $ cmake --version
> cmake version 3.10.2
> $ cmake .. 2>&1 | grep -A4 Error
> CMake Error at tests/xmltester/CMakeLists.txt:30 (target_link_libraries):
>   target.  One may link only to STATIC or SHARED libraries, or to
> executables
>   with the ENABLE_EXPORTS property set.
> Marking it as having Severity = Critical because it worked just fine with
> autotools but autotools have been removed from master branch, so I
> basically cannot build anymore until this is fixed.
New description:
 $ cmake --version
 executables
Ticket URL: <https://trac.osgeo.org/geos/ticket/1103#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
