[geos-devel] [GEOS] #1103: Target "tinyxml2" of type OBJECT_LIBRARY may not be linked into another target.
geos-trac at osgeo.org
Tue Mar 2 02:55:09 PST 2021
target.
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.9.2
Component: Build/Install (cmake) | Version: master
Severity: Critical | Resolution:
Keywords: |
Comment (by dbaston):
It looks like changes ( 3dd7121 ) I introduced to quiet compiler warnings
in vendored libraries require CMake 3.13. So this can be solved either by
updating `cmake_minimum_required` to 3.13, or reverting those changes and
accepting that we cannot use `-Werror` because of warnings from vendored
libraries.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1103#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
