[geos-devel] Gitea 3.10.0dev cmake broken
Roger Bivand
Roger.Bivand at nhh.no
Wed May 5 08:42:55 PDT 2021
Following the decision to drop autotools, I see that cmake generates (in
the current state of the gitea repo) a geos-config that points to
/usr/local/lib for installed shared objects on Linux, but installs in
/usr/local/lib64, leading to other programs not finding them. I know that
I can set symlinks, but geos-config should take the correct values. The
geos.pc file is in /usr/local/lib64/pkgconfig, and reads:
$ cat /usr/local/lib64/pkgconfig/geos.pc
prefix=/usr/local
exec_prefix=${prefix}
includedir=${prefix}/include
libdir=${prefix}/lib
Description: Geometry Engine, Open Source - C API
Requires:
Version: 3.10.0dev
Cflags: -I${includedir}
Libs: -L${libdir} -lgeos_c
also pointing at /usr/local/lib, not /usr/local/lib64. Was the instalation
to lib64 a recent change and was it intended?
Best wishes,
Roger
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
