[geos-devel] Gitea 3.10.0dev cmake broken
Roger Bivand
Roger.Bivand at nhh.no
Wed May 5 11:00:02 PDT 2021
Symlinks not needed, just adding /usr/local/lib64 so that ldconfig found
the *.so in /usr/local/lib64, which nothing else had used before. The
question however remains, was installing to lib64 a specific choice and
why do neither geos.pc nor geos-config advertise it?
Roger
On Wed, 5 May 2021, Roger Bivand wrote:
> Following the decision to drop autotools, I see that cmake generates (in the
> current state of the gitea repo) a geos-config that points to /usr/local/lib
> for installed shared objects on Linux, but installs in /usr/local/lib64,
> leading to other programs not finding them. I know that I can set symlinks,
> but geos-config should take the correct values. The geos.pc file is in
> /usr/local/lib64/pkgconfig, and reads:
> $ cat /usr/local/lib64/pkgconfig/geos.pc
> prefix=/usr/local
> exec_prefix=${prefix}
> includedir=${prefix}/include
> libdir=${prefix}/lib
> Description: Geometry Engine, Open Source - C API
> Requires:
> Version: 3.10.0dev
> Cflags: -I${includedir}
> Libs: -L${libdir} -lgeos_c
> also pointing at /usr/local/lib, not /usr/local/lib64. Was the instalation
> to lib64 a recent change and was it intended?
> Best wishes,
> Roger
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
