[geos-devel] Gitea 3.10.0dev cmake broken
Roger Bivand Roger.Bivand at nhh.no
Fri May 7 04:10:50 PDT 2021
On Fri, 7 May 2021, Even Rouault wrote:
>>  Yes, of course you are right, thanks! After removing it and with
>>  /usr/local/lib64/pkgconfig on the path (it was there before, but after
>>  /usr/local/lib/pkgconfig):
>>  $ pkg-config geos --libs
>>  -lgeos_c
>>  $ pkg-config geos --libs-only-L
>>  $ pkg-config geos --libs-only-l
>>  -lgeos_c
>>  $ pkg-config geos --static --libs
>>  -lgeos_c
>>  which still looks curious.
> I couldn't find the documentation for that, but I suspect that it strips
> paths that are one of the default linking paths (perhaps related to the ones
> of /etc/ld.conf.d/*)
> If you manually edit the geos.pc file to modify the -L to be something non
> standard, you should see the -L reappearing
Edited to libdir=${exec_prefix}/lib32:
-L/usr/local/lib32
so this looks like the smoking gun. So both geos.pc and geos-config are
most likely now OK, but I haven't tested geos.pc in a dependency
configure.
Roger
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
