[geos-devel] 3.9.2 Release?
Daniel Baston dbaston at gmail.com
Mon Nov 1 10:37:04 PDT 2021
+1
Dan
On Fri, Oct 29, 2021 at 9:43 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> I call for approval of a 3.9.2 release! (rah!)
> The list of fixes is pretty chunky at this point and it's been a while.
> +1 from me
> - Bug fixes / improvements:
>   - Add in interrupt points in OverlayNG (#4857, Paul Ramsey)
>   - Fix crash in GEOSPreparedIntersects and GEOSPreparedContains for
>     POINT EMPTY input (Even Rouault)
>   - Fix IsValidOp to correctly report invalid nested MultiPolygons (#1112,
> Martin Davis)
>   - Fix BufferOp to avoid artifacts in certain polygon buffers (#1101,
> Martin Davis)
>   - Declare parameterless functions in geos_c.h as func(void) (Paul Ramsey)
>   - Performance improvement in SegmentNodeList (Even Rouault)
>   - Catch memory leaks on createPolygon failure (#1111, Paul Ramsey)
>   - Fix DiscreteFrechetDistance to use initial points of input lines
> (#1128, Martin Davis)
>   - Avoid stack overflow in KdTree::queryNode (Even Roualt)
>   - Avoid raising double overflow signals in distance calcs (Paul Ramsey)
>   - Fix performance issue in buffer building (Paul Ramsey)
>   - Fix crash when precision reducing LinearRing (#1135, Paul Ramsey)
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20211101/4321904d/attachment.html>
