[geos-devel] 3.9.2 Release?
Paul Ramsey
pramsey at cleverelephant.ca
Mon Nov 1 11:33:08 PDT 2021
Hearing no cries of horror, I have done the release process for 3.9.2.
P
> On Nov 1, 2021, at 10:37 AM, Daniel Baston <dbaston at gmail.com> wrote:
> +1
> Dan
> On Fri, Oct 29, 2021 at 9:43 PM Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> I call for approval of a 3.9.2 release! (rah!)
> The list of fixes is pretty chunky at this point and it's been a while.
> +1 from me
> - Bug fixes / improvements:
> - Add in interrupt points in OverlayNG (#4857, Paul Ramsey)
> - Fix crash in GEOSPreparedIntersects and GEOSPreparedContains for
> POINT EMPTY input (Even Rouault)
> - Fix IsValidOp to correctly report invalid nested MultiPolygons (#1112, Martin Davis)
> - Fix BufferOp to avoid artifacts in certain polygon buffers (#1101, Martin Davis)
> - Declare parameterless functions in geos_c.h as func(void) (Paul Ramsey)
> - Performance improvement in SegmentNodeList (Even Rouault)
> - Catch memory leaks on createPolygon failure (#1111, Paul Ramsey)
> - Fix DiscreteFrechetDistance to use initial points of input lines (#1128, Martin Davis)
> - Avoid stack overflow in KdTree::queryNode (Even Roualt)
> - Avoid raising double overflow signals in distance calcs (Paul Ramsey)
> - Fix performance issue in buffer building (Paul Ramsey)
> - Fix crash when precision reducing LinearRing (#1135, Paul Ramsey)
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
