[geos-devel] GEOS 3.9.2 Released
Paul Ramsey
pramsey at cleverelephant.ca
Mon Nov 1 11:38:36 PDT 2021
Lots of little fixes piled up!
http://download.osgeo.org/geos/geos-3.9.2.tar.bz2
Changes in 3.9.2
2021-11-01
- Bug fixes / improvements:
- Add in interrupt points in OverlayNG (#4857, Paul Ramsey)
- Fix crash in GEOSPreparedIntersects and GEOSPreparedContains for
POINT EMPTY input (Even Rouault)
- Fix IsValidOp to correctly report invalid nested MultiPolygons (#1112, Martin Davis)
- Fix BufferOp to avoid artifacts in certain polygon buffers (#1101, Martin Davis)
- Declare parameterless functions in geos_c.h as func(void) (Paul Ramsey)
- Performance improvement in SegmentNodeList (Even Rouault)
- Catch memory leaks on createPolygon failure (#1111, Paul Ramsey)
- Fix DiscreteFrechetDistance to use initial points of input lines (#1128, Martin Davis)
- Avoid stack overflow in KdTree::queryNode (Even Roualt)
- Avoid raising double overflow signals in distance calcs (Paul Ramsey)
- Fix performance issue in buffer building (Paul Ramsey)
- Fix crash when precision reducing LinearRing (#1135, Paul Ramsey)
