[geos-devel] [GEOS] #1143: Release distribution contains generated files with "dev" in version
geos-trac at osgeo.org
Tue Nov 2 15:03:24 PDT 2021
Reporter: Mike Taves | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.10.1
Component: Default | Version: main
Severity: Unassigned | Resolution:
Keywords: |
Comment (by Mike Taves):
Now identical to the updated 3.10 branch, but the new
`CPACK_SOURCE_IGNORE_FILES` setting is too aggressive and appears to
exclude template files, and the source does not get past the
configuration:
$ cmake ..
CMake Error: File /tmp/from_trac/geos-3.10.1/include/geos/version.h.in
does not exist.
CMake Error at include/CMakeLists.txt:30 (configure_file):
configure_file Problem configuring file
CMake Error: File /tmp/from_trac/geos-3.10.1/tools/geos-config.in does not
exist.
CMake Error at tools/CMakeLists.txt:25 (configure_file):
Call Stack (most recent call first):
tools/CMakeLists.txt:65 (configure_install_geos_config)
do the new `CPACK_SOURCE_IGNORE_FILES` patterns need `$` to prevent
partial matches or something?
Ticket URL: <https://trac.osgeo.org/geos/ticket/1143#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
