[geos-devel] [GEOS] #1143: Release distribution contains generated files with "dev" in version
GEOS geos-trac at osgeo.org
Tue Nov 2 15:10:24 PDT 2021
 Reporter:  Mike Taves  |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.10.1
Component:  Default     |     Version:  main
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by Mike Taves):
 try this:
 diff --git a/CMakeLists.txt b/CMakeLists.txt
 index e5994bd..2b9161b 100644
 --- a/CMakeLists.txt
 +++ b/CMakeLists.txt
 @@ -417,8 +417,9 @@ if(NOT _is_multi_config_generator)
      "/php/"
      "/.*build-.*/"
      "cmake_install\\\\.cmake"
 -    "/include/geos/version\\\\.h"
 -    "/tools/geos-config"
 +    "/include/geos/version\\\\.h\$"
 +    "/tools/geos-config\$"
 +    "/tools/geos\\\\.pc\$"
      "/bin/"
      ${PROJECT_BINARY_DIR}
Ticket URL: <https://trac.osgeo.org/geos/ticket/1143#comment:8>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
