[geos-devel] [GEOS] #1143: Release distribution contains generated files with "dev" in version
GEOS geos-trac at osgeo.org
Tue Nov 2 15:16:28 PDT 2021
 Reporter:  Mike Taves  |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.10.1
Component:  Default     |     Version:  main
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by pramsey):
 Again, with your suggestion.
 ​http://download.osgeo.org/geos/test/geos-3.10.1.tar.bz2
 It's building here ATM.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1143#comment:9>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
