[geos-devel] [GEOS] #1143: Release distribution contains generated files with "dev" in version
GEOS geos-trac at osgeo.org
Tue Nov 2 15:28:19 PDT 2021
 Reporter:  Mike Taves  |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.10.1
Component:  Default     |     Version:  main
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by Mike Taves):
 That looks like it should do!
 Also, be aware that download links should use
 `https://download.osgeo.org`, as some modern browsers will refuse to
 download from unsecure "http" URLs.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1143#comment:10>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
