[geos-devel] 3.10.0beta2
Greg Troxel
gdt at lexort.com
Wed Oct 6 16:23:56 PDT 2021
Paul Ramsey <pramsey at cleverelephant.ca> writes:
> I found the relevant CMake line, and only the unit tests should be ending
> up with a link dependency to pthreads. So don't declare the library itself
> as having a pthread dependency. (Maybe next release, when we get all jiggy
> with multi-threaded performance work, ha ha ha)
> P
> --- from cmakelists.txt
> find_package(Threads)
> target_link_libraries(test_geos_unit PRIVATE geos geos_c Threads::Threads)
Interesting. I wonder if the tests should avoid threads if the library
isn't built with threads.
It seems obvious (maybe I'm wrong) that if a library is not built with
threads, then a threaded program that uses it must ensure that only one
library call is happening at any given time, either by calling it only
from one specific thread, or having a "call into geos" mutex.
I found that the geos library did get linked with -lpthread. I will
reproduce that and see if I can figure out why, after moving to rc3.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20211006/0cbcf0b0/attachment.sig>
