[geos-devel] 3.10.0beta2
Paul Ramsey
pramsey at cleverelephant.ca
Mon Oct 11 16:29:23 PDT 2021
> On Oct 10, 2021, at 9:51 AM, Greg Troxel <gdt at lexort.com> wrote:
> I've been looking into the test failures.
> My build passes LDFLAGS of -R/usr/pkg/lib, because pkgsrc builds to a
> prefix that is not part of the default search path. And, while geos
> does not depend on libraries from pkgsrc, in general packages depend on
> other packages and need to find their libs at runtime.
> The build of the tests programs use those LDFLAGS (which seems natural
> enough). This results in a bunch of libs being DT_NEEDED:
> $ objdump -x /tmp/work/geography/geos/work/geos-3.10.0beta3/bin/test_geos_unit
> [snip]
> Dynamic Section:
> NEEDED libgeos_c.so.1
> NEEDED libgeos.so.3.10.0
> NEEDED libpthread.so.1
> NEEDED libstdc++.so.9
> NEEDED libm.so.0
> NEEDED libgcc_s.so.1
> NEEDED libc.so.12
> RPATH /usr/pkg/lib
> [snip]
> which is all straightforward for a program to be installed.
> I still have not found any mechanism that attempts to arrange for the
> not-installed library to be used for the test.
> maybe the tests should be static?
I feel like there is an answer somewhere out there that a NetBSD expert could find and teach us, and I'd rather not bend around the whole setup of things because of a fairly niche platform issue. People can still *use* GEOS pretty easily on NetBSD (build/install/forget). The only thing they cannot easily do is run tests, which is inconvenient to a very small population, which I understand includes you but I hope you'll be OK with us continuing down the release path nonetheless.
P
