[geos-devel] cmake detailed comments
Paul Ramsey pramsey at cleverelephant.ca
Wed Oct 13 07:31:33 PDT 2021
> On Oct 13, 2021, at 1:29 AM, Sandro Santilli <strk at kbt.io> wrote:
> On Tue, Oct 12, 2021 at 07:18:11PM -0700, Paul Ramsey wrote:
>>> The tests are written as if they are regular code; tests in general need
>>> to be marked for special linking.  I don't see anything special there
>>> either.
>> I don't know what you mean, but I also like how our tests work now so...? :0)
> I guess he means that tests should be built so to use *just_built*
> libraries rather than system-installed libraries.
> What do you mean by "I like how our tests work now" ? How do they work
> for you ? Are them guaranteed to be using the *just_built* (rather
> than the *installed*) libraries ?
That is the case on all the platforms we've had reported except Gregs. Tests work against the libraries built in the build directory.
P
> --strk;
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
