[geos-devel] 3.10.0rc1 (static)
Paul Ramsey
pramsey at cleverelephant.ca
Fri Oct 15 07:56:18 PDT 2021
> On Oct 15, 2021, at 2:00 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> /usr/bin/ld: /home/rsb/static/lib64/libgeos.a(WKTWriter.cpp.o): in function `geos::io::WKTWriter::writeNumber[abi:cxx11](double) const':
> WKTWriter.cpp:(.text+0xe39): undefined reference to `geos_d2sfixed_buffered_n'
> collect2: error: ld returned 1 exit status
Somehow the ryu dependency is missing in the final library... I wonder if the "object library" trick is having deleterious effects in the case of building static libs.
P
