[geos-devel] 3.10.0rc1 (static)
Roger Bivand Roger.Bivand at nhh.no
Fri Oct 15 08:05:48 PDT 2021
On Fri, 15 Oct 2021, Paul Ramsey wrote:
>> On Oct 15, 2021, at 2:00 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>> /usr/bin/ld: /home/rsb/static/lib64/libgeos.a(WKTWriter.cpp.o): in function `geos::io::WKTWriter::writeNumber[abi:cxx11](double) const':
>> WKTWriter.cpp:(.text+0xe39): undefined reference to `geos_d2sfixed_buffered_n'
>> collect2: error: ld returned 1 exit status
> Somehow the ryu dependency is missing in the final library... I wonder
> if the "object library" trick is having deleterious effects in the case
> of building static libs.
Thanks; do you need me to check anything now? Happy to check when you
advise.
Roger
> P
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
