[geos-devel] 3.10.0rc1 (static)
Paul Ramsey pramsey at cleverelephant.ca
Fri Oct 15 08:06:49 PDT 2021
> On Oct 15, 2021, at 8:05 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> On Fri, 15 Oct 2021, Paul Ramsey wrote:
>>> On Oct 15, 2021, at 2:00 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>>> /usr/bin/ld: /home/rsb/static/lib64/libgeos.a(WKTWriter.cpp.o): in function `geos::io::WKTWriter::writeNumber[abi:cxx11](double) const':
>>> WKTWriter.cpp:(.text+0xe39): undefined reference to `geos_d2sfixed_buffered_n'
>>> collect2: error: ld returned 1 exit status
>> Somehow the ryu dependency is missing in the final library... I wonder if the "object library" trick is having deleterious effects in the case of building static libs.
> Thanks; do you need me to check anything now? Happy to check when you advise.
I think your recipe gives me enough to reproduce, which is what I'll check first. If I cannot reproduce I'll be back for more.
P.
> Roger
>> P
> Roger Bivand
> Emeritus Professor
> Department of Economics, Norwegian School of Economics,
> Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
> e-mail: Roger.Bivand at nhh.no
> https://orcid.org/0000-0003-2392-6140
> https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
