[geos-devel] 3.10.0rc1 (static)
Roger Bivand
Roger.Bivand at nhh.no
Fri Oct 15 08:20:31 PDT 2021
On Fri, 15 Oct 2021, Paul Ramsey wrote:
>>>> On Oct 15, 2021, at 2:00 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>>>> /usr/bin/ld: /home/rsb/static/lib64/libgeos.a(WKTWriter.cpp.o): in function `geos::io::WKTWriter::writeNumber[abi:cxx11](double) const':
>>>> WKTWriter.cpp:(.text+0xe39): undefined reference to `geos_d2sfixed_buffered_n'
>>>> collect2: error: ld returned 1 exit status
>>> Somehow the ryu dependency is missing in the final library... I wonder
>>> if the "object library" trick is having deleterious effects in the
>>> case of building static libs.
>> Thanks; do you need me to check anything now? Happy to check when you
>> advise.
> I think your recipe gives me enough to reproduce, which is what I'll
> check first. If I cannot reproduce I'll be back for more.
Good. I moved libryu.a to the installed lib64 directory and added -lryu to
the g++ command, and there immediate failure is gone. I added
libtinyxlm2.a too, because it was in the lib build directory. Adding -lryu
and -lstdc++ to geos-config manually for --static-cclibs and
--static-clibs permits the full check of the rgeos package to succeed. But
please double-check, these are tricks I'm not at all familiar with.
Roger
> P.
>> Roger
>>> P
>> Roger Bivand
>> Emeritus Professor
>> Department of Economics, Norwegian School of Economics,
>> Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
>> e-mail: Roger.Bivand at nhh.no
>> https://orcid.org/0000-0003-2392-6140
>> https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
Roger Bivand
Emeritus Professor
