[geos-devel] 3.10.0rc1 (static)
Greg Troxel
gdt at lexort.com
Fri Oct 15 11:27:47 PDT 2021
Paul Ramsey <pramsey at cleverelephant.ca> writes:
> OK, this is coming directly out of https://trac.osgeo.org/geos/ticket/1103
> If I go back to using an "OBJECT" library in building ryu, then it
> gets bundled right up into libgeos.a where we want it, and your link
> line is nice and simple again. That implies a minimum cmake of 3.13,
> whcih is 3+ years old now. My macports gives me 3.21 by default. I
> dunno, we backed out of the OBJECT library to STATIC to keep the cmake
> requirement low, but that implies generating two static libs and
> sticking them both on the link line.
> I'm inclined to bias towards a newer cmake and still generating one static library.
I'm usually in the camp of not wanting to have aggressive dependency
requirements, so having a look and opining.
pkgsrc has 3.21.2 now (and it looks like 3.21.3 just came out).
3.13.0 was released on 2018-11-20. That's almost 5 years ago, and I
therefore think it's entirely reasonable to require it if it makes
anything even a little bit better.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20211015/8ea6aaf9/attachment.sig>
