[geos-devel] 3.10.0 Release Vote
Paul Ramsey pramsey at cleverelephant.ca
Mon Oct 18 14:34:00 PDT 2021
Um,
- plenty of betas, plenty of rc,
- the configure thing is your own addition: fix it to force a nocache, or just drop it,
- and we're also re-litigating cmake too (the docs unambiguously provide out-of-tree examples only)?
- geosop is not mission critical, it can be patched up in micro releases.
P.
> On Oct 18, 2021, at 2:27 PM, Sandro Santilli <strk at kbt.io> wrote:
> On Mon, Oct 18, 2021 at 01:33:52PM -0700, Paul Ramsey wrote:
>> Having gone through numerous beta and rc releases, and hearing no
>> further screams of agony, I call the vote on releasing 3.10.0.
>> +1
> I know I'm late to the party but I'm trying builds on multiple
> machines now.
> The fist thing that did strike me was that a new ./configure (cmake)
> run did NOT result in proper update of all the configuration, but still
> remembered my previous cmake run defines so ended up installing GEOS in
> /tmp/geos10 (from the tests I was doing with RUNPATH).
> I tried `make distclean` but such target is not present.
> I know, `rm -rf <buildtree>` is the cmake way, and I was lucky
> to be able to do that, but if you build in the source tree
> that's not something you can do easily.
> Second thing:
>  $ geosop help test
>  terminate called after throwing an instance of 'std::invalid_argument'
>    what():  stod
>  Aborted (core dumped)
> I'd rather not install `geosop` than letting it core-dump so easily.
> It was ticketed as https://trac.osgeo.org/geos/ticket/1126 and then
> retargetted to 3.11 milestone, but really, I think we shouldn't
> release with such known behaviour.
> --strk;
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
