[geos-devel] The Road to 3.10
Paul Ramsey
pramsey at cleverelephant.ca
Fri Sep 10 16:15:42 PDT 2021
One thing worthy of discussion is pushing forward the cmake dependency. If we pop forward to 3.12 we can fix this issue cleanly by using OBJECT instead of STATIC linking for our vendored deps.
https://github.com/libgeos/geos/issues/463
3.12.0 was released in 2018. I personally at this point just use the latest cmake build, which is so easy to do (download package, unzip in /usr/local).
P
> On Sep 10, 2021, at 4:03 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> We may have one last piece of functionality to add to 3.10 (new triangulation code) and then will start the count-down to release. If you've got work in progress that is suitable for 3.10, this would be a good time to bring it home.
> P
