[geos-devel] The Road to 3.10
Greg Troxel
gdt at lexort.com
Fri Sep 10 17:35:08 PDT 2021
Paul Ramsey <pramsey at cleverelephant.ca> writes:
> One thing worthy of discussion is pushing forward the cmake
> dependency. If we pop forward to 3.12 we can fix this issue cleanly by
> using OBJECT instead of STATIC linking for our vendored deps.
> https://github.com/libgeos/geos/issues/463
> 3.12.0 was released in 2018. I personally at this point just use the
> latest cmake build, which is so easy to do (download package, unzip in
> /usr/local).
I am a trailing edge type. 3.12 from 2018 sounds ancient even to me and
it's hard to believe any system with 3.11 can cope with much of anything
these days.
So changing the cmake rule to 3.12 seems entirely reasonable.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20210910/b10f813d/attachment.sig>
