[geos-devel] The Road to 3.10
Regina Obe
lr at pcorp.us
Wed Sep 29 13:16:00 PDT 2021
> > > I'm on it now, will be ready (it's just stubs) in a few hours.
> > The implication being we'll roll a big change into a micro release later
on?
> This is also Less Than Ideal, even if the API remains constant, I would
think.
> I'll try making it less than a stub.
> I just discovered we DO have a Geometry::isWithinDistance(), which is
> basically also a stub, as it does NOT currently use the DistanceOp support
for
> early terminating the computations. Might improve that as well.
> Not sure how to possibly improve the PreparedWithinDistance though, as
> maybe there's not much to improve there.
> --strk;
[Regina Obe]
If you are simply exposing functionality that was already in C++ API in the
C-API then I retract my -1. If you are doing more than that - like planning
to rewrite said C++ logic, my -1 stands.
