[geos-devel] GEOS Maintenance Grant
Andrew Bell
andrew.bell.ia at gmail.com
Fri Feb 18 16:15:45 PST 2022
Has the attitude about keeping the codebase in sync with the JTS code
changed? I would potentially do some work on this project if this isn't a
requirement -- it seemed difficult to make changes that would make the code
more accessible with strict adherence to the JTS structure.
Sorry if this isn't the right thread for this question.
On Fri, Feb 18, 2022 at 6:52 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> While I appreciate the sentiment behind this, I do not believe the
> particular breakdown below is reflective of the current needs of this
> project.
> - This is a library. The users of the project are not pro-sumers or
> non-technical, they are C and C++ developers. Users who are not C and C++
> developers are supported by the particular project that is embedding the
> library, whether it be PostGIS, QGID, GDAL or Shapely. The documentation
> requirements are therefore relatively meagre.
> - This is a library with 15 years of technical debt. From its very birth,
> GEOS was built on foundations of sand. Hewing over-closely to the JTS code,
> it built up a burden of heal-allocations that have only been slowly pared
> back. The first professional services contract I let for improvements
> was... to track down the huge piles of memory leaks generated by that
> festival of heap allocations. Between the date of birth in the early 2000's
> to now, the C++ language itself has been transformed (several times),
> leaving the code base in a somewhat mish-mash state, some "modern" other
> ... not.
> - This is a library with some big jobs that are no fun and yet fairly
> foundational. Off the top of my head: support for M coordinates and
> rationalizing that against an efficient implementation of
> coordinatesequences, support for ISO circular arc geometry structures,
> efficient use of in-place data for more 'no-copy' operations.
> The breakdown below perhaps makes sense for a project like QGIS, but for a
> this particular project with this projects current needs, focussing on
> development and developer-level documentation needs (good/better doxygen,
> example programs, consistent and clear in-code commenting) for this round
> is where we are going to go.
> ATB,
> P
> > On Feb 17, 2022, at 1:20 PM, Jeff McKenna <jmckenna at gatewaygeomatics.com>
> wrote:
> > Dear GEOS PSC,
> > Great to hear about a grant to help the project along.
> > My feedback is to make sure that the funds are spread around, not just
> to one developer, but also to the (even more critical) parts of software
> projects that never receive funding, yet are so important to end-users:
> documentation, testing, and packaging.
> > I know it is 2022, and we have so many corporate influences in FOSS4G
> that it's hard to see through the activity/smoke, but, we should always try
> to make sure that the funds are spread around to as many parts of the
> project as possible. For example, 50k USD could be shared by the GEOS PSC
> as:
> > - 25k development
> > - 10k documentation
> > - 10k packaging
> > - 5k testing and releases
> > That is a fair plan for actual project "maintenance". QGIS.ORG (the
> registered entity behind QGIS) & the QGIS PSC does an excellent job at
> spreading the funding around to all parts of the project, which creates a
> "product" feeling to QGIS (a well-rounded result).
> > My rule of thumb, is that for every 1 hour of development in a software
> project spent, it should take approximately 8 hours of further testing,
> documentation, and packaging by others, if done properly. (instead of one
> funded developer doing an hour of development, and squeezing in a few
> minutes of docs often by the same developer).
> > I hope my feedback can be received well by the GEOS PSC, and they could
> keep this feedback in mind the next time funding comes along.
> > Thanks, sent from the east coast of Canada,
> > -jeff
> > Jeff McKenna
> > GatewayGeo: Developers of MS4W, MapServer Consulting and Training
> > co-founder of FOSS4G
> > http://gatewaygeo.com/
> > On 2022-02-15 11:37 a.m., Howard Butler wrote:
> >> GDAL PSC,
> >> When we wrote the GDAL RFCs on sponsorship, we provided an escape
> clause to allow us to direct resources to other projects upon which GDAL
> depends. Our sponsorship numbers are still increasing, which provides us an
> opportunity to directly support some of those projects, and one of them is
> obviously GEOS. GEOS provides all of the geometry algebra support for
> GDAL/OGR and many other open source geospatial softwares including Shapely,
> PostGIS, GeoPandas, MapServer, and more.
> >> Dan Baston of the GEOS PSC has been identified as the developer with
> capacity and interest in the next year to take on GEOS development on APIs
> and performance, which he has a long history of doing for the project. This
> support should allow him to work longer, multi-release upgrades that will
> provide strong performance and convenience benefits for the project.
> >> I motion to provide the GEOS PSC with a $50,000 USD grant to address
> performance, API, and other work that does not attract directed funding in
> GEOS. The GEOS PSC will be responsible for coordinating work tasks, rates,
> and development timelines. Howard Butler or Even Rouault of the GDAL
> NumFocus liaison team will coordinate dispersement as directed by the GEOS
> PSC and NumFocus rules.
> >> Thank you again to the GDAL Sponsors
> https://gdal.org/sponsors/index.html who have made this kind of grant
> possible. A better GEOS makes for a better GDAL.
> >> Howard
> > geos-devel mailing list
> > geos-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geos-devel
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20220218/457a1eb1/attachment.html>
