[geos-devel] build failure of 3.10.3 on smartos (= illumos)
Paul Ramsey
pramsey at cleverelephant.ca
Tue Jun 21 15:35:38 PDT 2022
Thanks!
Going to run this through the CI grinder.
https://github.com/libgeos/geos/pull/641
P
> On Jun 21, 2022, at 3:30 PM, Even Rouault <even.rouault at spatialys.com> wrote:
> Since C++11, std::sqrt() is required to have an integral overload. See https://en.cppreference.com/w/cpp/numeric/math/sqrt
> Looking at https://github.com/google/sentencepiece/issues/432#issuecomment-639434698, it seems this is a known defect of Solaris world
> Using 5.0 should be a no-brainer and portable fix.
> Le 22/06/2022 à 00:22, Greg Troxel a écrit :
>> Paul Ramsey <pramsey at cleverelephant.ca> writes:
>>> Well, it's super rare, platformwise so I don't really categorize it as
>>> "our problem", but it's nice to be clearer. What's the simplest way to
>> I said smartos but this is almost certainly most if not all solaris.
>>> even find out if a change fixes this? I'm tempted to make everything
>>> std::sqrt() on some kind of principle, but I have no idea if that will
>>> actually change anything. Probably just changing the 5 to 5.0 would do
>>> the trick.
>> With a candidate change, I can apply it and see what happens. I don't
>> know the C++ rules well enough to pick something that is correct by
>> spec.
>> If your preferred approach is changing to 5.0 (which I presume is a
>> double constant since it is not 5.0f), then I can try that.
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geos-devel
> http://www.spatialys.com
> My software is free, but my time generally not.
