[geos-devel] build failure of 3.10.3 on smartos (= illumos)
Even Rouault even.rouault at spatialys.com
Tue Jun 21 15:30:35 PDT 2022
Since C++11, std::sqrt() is required to have an integral overload. See
https://en.cppreference.com/w/cpp/numeric/math/sqrt
Looking at
https://github.com/google/sentencepiece/issues/432#issuecomment-639434698,
it seems this is a known defect of Solaris world
Using 5.0 should be a no-brainer and portable fix.
Le 22/06/2022 à 00:22, Greg Troxel a écrit :
> Paul Ramsey <pramsey at cleverelephant.ca> writes:
>> Well, it's super rare, platformwise so I don't really categorize it as
>> "our problem", but it's nice to be clearer. What's the simplest way to
> I said smartos but this is almost certainly most if not all solaris.
>> even find out if a change fixes this? I'm tempted to make everything
>> std::sqrt() on some kind of principle, but I have no idea if that will
>> actually change anything. Probably just changing the 5 to 5.0 would do
>> the trick.
> With a candidate change, I can apply it and see what happens.   I don't
> know the C++ rules well enough to pick something that is correct by
> spec.
> If your preferred approach is changing to 5.0 (which I presume is a
> double constant since it is not 5.0f), then I can try that.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
http://www.spatialys.com
