[geos-devel] GEOS for 3/more-dimensional polyhedra
Muthu Vallinayagam
muthu.vallin at gmail.com
Tue Mar 29 08:04:50 PDT 2022
Dear GEOS developers and users,
first, I thank developers for developing geos. I am using it, but
indirectly, via the Shapely package.
I am using Shapely for my project, which deals with 2-dimensional Polygons.
I need such a package
for 3-dimensional polyhedra and in later cases for 4-d, 5-d, etc., But
presently Shapely supports only
2-dimensional polygons since GEOS supports only 2-dimension.
*so I would like to request the developers about the addition of
a 3-dimension feature in GEOS.*
*I hope that it is to activate one more dimension in the C/C++ array and
change respective algorithms*
*in set operation definitions. *
*Also using calloc and malloc we can leave array dimensions to be filled
dynamically. for example, if Geos*
*is exported as a module in python **script, the first thing user can set
the array dimension as per the needs. *
*If they deal with polygons the dimension is set to be 2 **and for
polyhedra, it is 3.*
*My overall needs are Polygon, Multipolygons, Union, and the intersection
of multipolygons. So *
If I want to change the libs in GEOS what are the libs should I change
first?
is it enough, if I change only the dimension of the array and Set operation
definitions in GEOS library for further applications in higher dimensions?
Looking forward to your hearing
thank you
Best regards
Muthu Vallinayagam,
Postdoctorate,
Institute for Experimental physics,
TU Freiberg, Germany
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20220329/90bb60e0/attachment.html>
