[geos-devel] GEOS 3.12 regression failure in PostGIS
Regina Obe lr at pcorp.us
Fri Oct 21 10:18:25 PDT 2022
I’m fine with the behavior changing and agree it makes sense.  Only issue is with it breaking someone’s existing good.  Though I’d doubt if anyone would rely on that as an output, but you never know.
I think it’s still good to have a test for it in GEOS to catch these, so it can at least be noted in notes as a breaking change.
I’ll take the test out of PostGIS if the behavior is kept in GEOS.
Thanks,
Regina
From: geos-devel [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Martin Davis
Sent: Friday, October 21, 2022 12:48 PM
To: GEOS Development List <geos-devel at lists.osgeo.org>
Subject: Re: [geos-devel] GEOS 3.12 regression failure in PostGIS
Validity is only tested in the XY dimensions.  So it's actually more appropriate that only the XY value is reported.
On Fri, Oct 21, 2022 at 7:35 AM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
Hi all,
PostGIS geos310 regression test, detailed here:
https://trac.osgeo.org/postgis/ticket/5260
Started failing around October 18th.
The test is this:
SELECT '#168', ST_NPoints(g), ST_AsText(g), ST_isValidReason(g)
FROM ( VALUES
('01060000C00100000001030000C00100000003000000E3D9107E234F5041A3DB66BC97A30F
4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440D
AF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFF
FFFFFFEFFF'::geometry)
) AS v(g);
I'm guessing might be caused by this commit -
https://github.com/libgeos/geos/commit/32348a68c5212c89cfefab46891d2b3aada4a <https://github.com/libgeos/geos/commit/32348a68c5212c89cfefab46891d2b3aada4ab40>
b40
which happened around the same time tests started failing.
The difference from prior versions is that the 3.12 (main branch) now emits
for isValidReason one less coordinate
Too few points in geometry component[4275341.96977851 259186.966993061]
Instead of:
1323.76295828331]
Which to me makes sense if we are only considering 2 dimensions for
validity.
Before I change the test, I want to confirm that this is an intentional
change.
Thanks,
Regina
geos-devel mailing list
geos-devel at lists.osgeo.org <mailto:geos-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20221021/251f109c/attachment.htm>
