[geos-devel] GEOS C API for Polygonal Coverage operations?
Martin Davis
mtnclimb at gmail.com
Wed Sep 7 15:44:10 PDT 2022
On Wed, Sep 7, 2022 at 3:18 PM Sandro Santilli <strk at kbt.io> wrote:
> On Tue, Sep 06, 2022 at 02:37:37PM -0700, Martin Davis wrote:
> > I've started to build out operations on Polygonal Coverages in JTS ([1],
> > [2]).
> > A key question is how to expose these operations in the GEOS C API. I
> see
> > two options:
> > 1) Model a Polygonal Coverage as an array of simple Polygons (and
> possibly
> > MultiPolygons)
> > 2) Provide a Polygonal Coverage datatype (which might contain internal
> > topology)
> Could a coverage datatype allow performing operations on PostGIS Topologies
> w/out building the polygons for each face ?
The short answer is "yes, probably, if suitable builders are defined for
the coverage datatype". But that starts getting complex (in particular, it
probably requires a concept of a Face, which might also have to be
exposed). This is quite a bit more design than the current work requires.
The other question is: what operations? Edge-based operations like
simplification (and maybe smoothing) don't really require a coverage at all
- they can simply operate on edge linework. That would be even easier to
use from PostGIS Topology, I expect. In fact, I'm considering factoring
out the "Topology-Preserving Line Simplification" part from the
CoverageSimplifier, so it can be used standalone.
> There's an ISO standard
> representation of topologies, maybe such representation could be used
> to transfer those topologies back and forth with GEOS ?
Not familiar with that representation. How does it handle identity for
Faces of topologies?
What we need to define is a C-based API for Coverage. It's not a huge
design space, so there would probably be similarities.
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20220907/c8e5a540/attachment.htm>
