[geos-devel] GEOS C API for Polygonal Coverage operations?
Sandro Santilli
strk at kbt.io
Thu Sep 8 08:53:09 PDT 2022
On Wed, Sep 07, 2022 at 03:44:10PM -0700, Martin Davis wrote:
> On Wed, Sep 7, 2022 at 3:18 PM Sandro Santilli <strk at kbt.io> wrote:
> > On Tue, Sep 06, 2022 at 02:37:37PM -0700, Martin Davis wrote:
> > > I've started to build out operations on Polygonal Coverages in JTS ([1],
> > > [2]).
> > > A key question is how to expose these operations in the GEOS C API. I
> > see
> > > two options:
> > > 1) Model a Polygonal Coverage as an array of simple Polygons (and
> > possibly
> > > MultiPolygons)
> > > 2) Provide a Polygonal Coverage datatype (which might contain internal
> > > topology)
> > Could a coverage datatype allow performing operations on PostGIS Topologies
> > w/out building the polygons for each face ?
> The short answer is "yes, probably, if suitable builders are defined for
> the coverage datatype". But that starts getting complex (in particular, it
> probably requires a concept of a Face, which might also have to be
> exposed). This is quite a bit more design than the current work requires.
It really depends on what you mean by "Coverage" really.
All I'm hoping for is that when using TopoGeometry objects I don't
have to build Geometry objects from them for the SOLE PURPOSE of
feeding them to GEOS which on its side would re-compute noding and
labeling which was already known by the TopoGeometry objects itself.
> > There's an ISO standard
> > representation of topologies, maybe such representation could be used
> > to transfer those topologies back and forth with GEOS ?
> Not familiar with that representation. How does it handle identity for
> Faces of topologies?
Faces are identified by an integer value, referenced by edges
(attributes: left_face, right_face)
See http://strk.kbt.io/projects/postgis/topology-ER.pdf
--strk;
