[geos-devel] 3.12.0beta1
Roger Bivand Roger.Bivand at nhh.no
Mon Jun 12 05:03:16 PDT 2023
An R packages built against GEOS is showing new test failures with 3.12.0beta1. The important terra package fails first at a union on a buffered object, other failures may occur later, but testing stops at first error. The error is:
Error: IllegalArgumentException: Overlay input is mixed-dimension
The abbreviated input in R is:
library(terra)
gdal(lib="geos")
# [1] "3.12.0beta1"
v <- vect(system.file("ex/lux.shp", package="terra"))
b <- buffer(v, 1000) # 1000m even though v are in degrees
u <- union(b)
# Error: IllegalArgumentException: Overlay input is mixed-dimension
The input shapefile may be found at https://github.com/rspatial/terra/tree/master/inst/ex/lux.*
I'm unsure whether this is change intentional, should I provide a WKT of the shapefile geometries, possibly planar?
Best wishes,
Roger
Roger Bivand
Emeritus Professor
Norwegian School of Economics
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway
