[geos-devel] 3.12.0beta1
Daniel Baston dbaston at gmail.com
Mon Jun 12 06:01:02 PDT 2023
Thanks for raising this. There was some discussion of the issue at
https://github.com/libgeos/geos/issues/797 and other tickets linked from
there, but it was never really resolved.
Dan
On Mon, Jun 12, 2023 at 8:52 AM Roger Bivand <Roger.Bivand at nhh.no> wrote:
> An R packages built against GEOS is showing new test failures with
> 3.12.0beta1. The important terra package fails first at a union on a
> buffered object, other failures may occur later, but testing stops at first
> error. The error is:
> Error: IllegalArgumentException: Overlay input is mixed-dimension
> The abbreviated input in R is:
> library(terra)
> gdal(lib="geos")
> # [1] "3.12.0beta1"
> v <- vect(system.file("ex/lux.shp", package="terra"))
> b <- buffer(v, 1000) # 1000m even though v are in degrees
> u <- union(b)
> # Error: IllegalArgumentException: Overlay input is mixed-dimension
> The input shapefile may be found at
> https://github.com/rspatial/terra/tree/master/inst/ex/lux.*
> I'm unsure whether this is change intentional, should I provide a WKT of
> the shapefile geometries, possibly planar?
> Best wishes,
> Roger
> Roger Bivand
> Emeritus Professor
> Norwegian School of Economics
> Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20230612/cc2769a6/attachment.htm>
