[geos-devel] 3.12.0beta1
Paul Ramsey
pramsey at cleverelephant.ca
Tue Jun 13 09:00:29 PDT 2023
I have taken a swipe at it here.
https://github.com/libgeos/geos/pull/923
> On Jun 12, 2023, at 6:01 AM, Daniel Baston <dbaston at gmail.com> wrote:
> Thanks for raising this. There was some discussion of the issue at https://github.com/libgeos/geos/issues/797 and other tickets linked from there, but it was never really resolved.
> Dan
> On Mon, Jun 12, 2023 at 8:52 AM Roger Bivand <Roger.Bivand at nhh.no <mailto:Roger.Bivand at nhh.no>> wrote:
>> An R packages built against GEOS is showing new test failures with 3.12.0beta1. The important terra package fails first at a union on a buffered object, other failures may occur later, but testing stops at first error. The error is:
>> Error: IllegalArgumentException: Overlay input is mixed-dimension
>> The abbreviated input in R is:
>> library(terra)
>> gdal(lib="geos")
>> # [1] "3.12.0beta1"
>> v <- vect(system.file("ex/lux.shp", package="terra"))
>> b <- buffer(v, 1000) # 1000m even though v are in degrees
>> u <- union(b)
>> # Error: IllegalArgumentException: Overlay input is mixed-dimension
>> The input shapefile may be found at https://github.com/rspatial/terra/tree/master/inst/ex/lux.*
>> I'm unsure whether this is change intentional, should I provide a WKT of the shapefile geometries, possibly planar?
>> Best wishes,
>> Roger
>> Roger Bivand
>> Emeritus Professor
>> Norwegian School of Economics
>> Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org <mailto:geos-devel at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20230613/cc123982/attachment.htm>
