[geos-devel] 3.12.0beta2
Greg Troxel
gdt at lexort.com
Thu Jun 15 06:30:14 PDT 2023
I have no clear memory of whether I ever tried to build geos or run
tests on RPI3 before. I have a very very vague memory of having trouble
and never having chased it down. So I am definitely not asking that the
release be held for this!
> https://download.osgeo.org/geos/geos-3.12.0beta2.tar.bz2
I am using
gcc version 7.5.0 (nb4 20200810)
On NetBSD 9 amd64, after installing it, tests all pass.
[snip]
Start 466: xml-validate-TestRelatePP
466/466 Test #466: xml-validate-TestRelatePP .................................. Passed 0.01 sec
100% tests passed, 0 tests failed out of 466
Total Test time (real) = 20.89 sec
On NetBSD 9 earmv7hf-el (RPI3 hardware, specifically), after installing
it, most but not all tests pass. I ran it twice with the same results
96% tests passed, 18 tests failed out of 465
Total Test time (real) = 111.91 sec
The following tests did not run:
377 - xml-issue-issue-geos-837 (Disabled)
The following tests FAILED:
25 - unit-algorithm-construct-MaximumInscribedCircle (Subprocess aborted)
32 - unit-capi-GEOSBuffer (Subprocess aborted)
35 - unit-capi-GEOSClipByRect (Subprocess aborted)
42 - unit-capi-GEOSCoordSeq (Subprocess aborted)
62 - unit-capi-GEOSGeomGeoJSONRead (Subprocess aborted)
94 - unit-capi-GEOSInterrupt (Subprocess aborted)
104 - unit-capi-GEOSMaximumInscribedCircle (Subprocess aborted)
140 - unit-capi-GEOSUnaryUnion (Subprocess aborted)
143 - unit-capi-GEOSUnion (Subprocess aborted)
168 - unit-geom-Dimension (Subprocess aborted)
212 - unit-io-GeoJSONReader (Subprocess aborted)
233 - unit-operation-buffer-BufferOp (Subprocess aborted)
240 - unit-operation-distance-IndexedFacetDistance (Subprocess aborted)
300 - xml-general-TestBuffer (Subprocess aborted)
305 - xml-general-TestDensify (Subprocess aborted)
361 - xml-issue-issue-geos-366 (Subprocess aborted)
373 - xml-issue-issue-geos-605 (Subprocess aborted)
399 - xml-misc-safe-TestBufferJagged (Subprocess aborted)
Errors while running CTest
Output from these tests are in: /d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/Testing/Temporary/LastTest.log
Use "--rerun-failed --output-on-failure" to re-run the failed cases verbosely.
gmake[4]: *** [Makefile:91: test] Error 8
gmake[4]: Leaving directory '/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2'
*** Error code 2
Looking at the logs (at end), overall this smells like either a
systematic issue where the floating point on my system is broken, or
there is some slight floating point difference from x86, and geos tests
are very sensitive to exact FP results. But that's just guessing.
I'm building for NetBSD 9 i386 and will also try macOS x86_64.
FWIW, I ran paranoia and got:
No failures, defects nor flaws have been discovered.
Rounding appears to conform to the proposed IEEE standard P754.
The arithmetic diagnosed appears to be Excellent!
I am curious if others have been running tests on CPUs other than x86,
and on those systems, if other than GNU/Linux.
Here's the output of "ctest --rerun-failed --output-on-failure":
Test project /usr/pkgsrc/geography/geos/work/geos-3.12.0beta2
Start 25: unit-algorithm-construct-MaximumInscribedCircle
1/18 Test #25: unit-algorithm-construct-MaximumInscribedCircle ...Subprocess aborted***Exception: 0.40 sec
GEOS Unit Test Suite
geos::algorithm::construct::MaximumInscribedCircle: .......terminate called after throwing an instance of 'geos::util::GEOSException'
what(): Non-finite envelope encountered.
Start 32: unit-capi-GEOSBuffer
2/18 Test #32: unit-capi-GEOSBuffer ..............................Subprocess aborted***Exception: 0.09 sec
capi::GEOSBuffer: .....................NOTICE: IllegalArgumentException: Invalid buffer endCap style
NOTICE: IllegalArgumentException: Invalid buffer join style
what(): Shell empty after removing invalid points
Start 35: unit-capi-GEOSClipByRect
3/18 Test #35: unit-capi-GEOSClipByRect ..........................Subprocess aborted***Exception: 0.09 sec
capi::GEOSClipByRect: .............terminate called after throwing an instance of 'geos::util::IllegalArgumentException'
what(): IllegalArgumentException: Invalid number of points in LinearRing found 3 - must be 0 or >= 4
Start 42: unit-capi-GEOSCoordSeq
4/18 Test #42: unit-capi-GEOSCoordSeq ............................Subprocess aborted***Exception: 0.08 sec
capi::GEOSCoordSeq: ..terminate called after throwing an instance of 'geos::util::IllegalArgumentException'
what(): IllegalArgumentException: Unknown ordinate index 37
Start 62: unit-capi-GEOSGeomGeoJSONRead
5/18 Test #62: unit-capi-GEOSGeomGeoJSONRead .....................Subprocess aborted***Exception: 0.09 sec
capi::GEOSGeomGeoJSONRead: ..terminate called after throwing an instance of 'geos_nlohmann::detail::parse_error'
what(): [json.exception.parse_error.101] parse error at line 1, column 1: syntax error while parsing value - invalid literal; last read: '<'
Start 94: unit-capi-GEOSInterrupt
6/18 Test #94: unit-capi-GEOSInterrupt ...........................Subprocess aborted***Exception: 0.09 sec
capi::GEOSInterrupt: ...terminate called after throwing an instance of 'geos::util::InterruptedException'
what(): InterruptedException: Interrupted!
Start 104: unit-capi-GEOSMaximumInscribedCircle
7/18 Test #104: unit-capi-GEOSMaximumInscribedCircle ..............Subprocess aborted***Exception: 0.09 sec
capi::GEOSMaximumInscribedCircle: ..terminate called after throwing an instance of 'geos::util::GEOSException'
Start 140: unit-capi-GEOSUnaryUnion
8/18 Test #140: unit-capi-GEOSUnaryUnion ..........................Subprocess aborted***Exception: 0.09 sec
capi::GEOSUnaryUnion: ........terminate called after throwing an instance of 'geos::util::GEOSException'
what(): Edge direction cannot be determined because endpoints are equal
Start 143: unit-capi-GEOSUnion
9/18 Test #143: unit-capi-GEOSUnion ...............................Subprocess aborted***Exception: 0.08 sec
capi::GEOSUnion: .terminate called after throwing an instance of 'geos::util::GEOSException'
Start 168: unit-geom-Dimension
10/18 Test #168: unit-geom-Dimension ...............................Subprocess aborted***Exception: 0.08 sec
geos::geom::Dimension: ..terminate called after throwing an instance of 'geos::util::IllegalArgumentException'
what(): IllegalArgumentException: Unknown dimension value: 101
Start 212: unit-io-GeoJSONReader
11/18 Test #212: unit-io-GeoJSONReader .............................Subprocess aborted***Exception: 0.10 sec
geos::io::GeoJSONReader: ......................terminate called after throwing an instance of 'geos_nlohmann::detail::parse_error'
Start 233: unit-operation-buffer-BufferOp
12/18 Test #233: unit-operation-buffer-BufferOp ....................Subprocess aborted***Exception: 0.15 sec
geos::operation::buffer::BufferOp: ..........terminate called after throwing an instance of 'geos::util::TopologyException'
what(): TopologyException: assigned depths do not match at -22625.315179557714 130450.31702346609
Start 240: unit-operation-distance-IndexedFacetDistance
13/18 Test #240: unit-operation-distance-IndexedFacetDistance ......Subprocess aborted***Exception: 3.01 sec
geos::operation::distance::IndexedFacetDistance: ..........terminate called after throwing an instance of 'geos::util::GEOSException'
what(): Cannot calculate IndexedFacetDistance on empty geometries.
Start 300: xml-general-TestBuffer
14/18 Test #300: xml-general-TestBuffer ............................Subprocess aborted***Exception: 0.12 sec
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case1: test1: buffer(A, -1.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case1: test2: buffer(A, 0.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case1: test3: buffer(A, 10.0): ok. (3 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case2: test1: buffer(A, -1.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case2: test2: buffer(A, 0.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case2: test3: buffer(A, 10.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case3: test1: buffer(A, -100.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case3: test2: buffer(A, -10.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case3: test3: buffer(A, 0.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case3: test4: buffer(A, 10.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case3: test5: buffer(A, 20.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case3: test6: buffer(A, 100.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case4: test1: buffer(A, -100.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case4: test2: buffer(A, -10.0): ok. (1 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case4: test3: buffer(A, 0.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case4: test4: buffer(A, 10.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case4: test5: buffer(A, 20.0): ok. (1 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestBuffer.xml: case4: test6: buffer(A, 100.0): ok. (0 ms)
what(): TopologyException: assigned depths do not match at 1335583.1400354072 631780.66133557539
Start 305: xml-general-TestDensify
15/18 Test #305: xml-general-TestDensify ...........................Subprocess aborted***Exception: 0.05 sec
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case1: test1: densify(A, 10.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case2: test1: densify(A, 10.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case3: test1: densify(A, 10.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case4: test1: densify(A, 10.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case5: test1: densify(A, 10.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case6: test1: densify(A, 10.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case7: test1: densify(A, 10.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case8: test1: densify(A, 2.999999): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case9: test1: densify(A, 6): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case10: test1: densify(A, 6): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case11: test1: densify(A, 6): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case12: test1: densify(A, 3): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case13: test1: densify(A, 2.999999): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case14: test1: densify(A, 10.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case15: test1: densify(A, 5.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case16: test1: densify(A, 2.999999): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case17: test1: densify(A, 10.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case18: test1: densify(A, 5.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case19: test1: densify(A, 10.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case20: test1: densify(A, 5.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case21: test1: densify(A, 2.999999): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case22: test1: densify(A, 10.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case23: test1: densify(A, 5.0): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case24: test1: densify(A, 2.999999): ok. (0 ms)
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/general/TestDensify.xml: case25: test1: densify(A, 0): ok. (0 ms)
what(): Tolerance is too small compared to geometry length
Start 361: xml-issue-issue-geos-366
16/18 Test #361: xml-issue-issue-geos-366 ..........................Subprocess aborted***Exception: 0.06 sec
what(): TopologyException: unable to find edge to compute depths at at -200016.32214116989 249553.4006244911
Start 373: xml-issue-issue-geos-605
17/18 Test #373: xml-issue-issue-geos-605 ..........................Subprocess aborted***Exception: 0.06 sec
what(): TopologyException: assigned depths do not match at 374252.37027537922 6136822.6948443819
Start 399: xml-misc-safe-TestBufferJagged
18/18 Test #399: xml-misc-safe-TestBufferJagged ....................Subprocess aborted***Exception: 2.04 sec
/d0/n0/pkgsrc/geography/geos/work/geos-3.12.0beta2/tests/xmltester/tests/misc/safe-TestBufferJagged.xml: case1: test1: buffer(a, 0.35): ok. (100 ms)
what(): TopologyException: assigned depths do not match at 99725.701985377294 -2239208.6167892241
0% tests passed, 18 tests failed out of 18
Total Test time (real) = 6.94 sec
