[geos-devel] 3.12.0beta1
Roger Bivand Roger.Bivand at nhh.no
Fri Jun 16 08:03:15 PDT 2023
Using the https://github.com/libgeos/geos/tree/3.11 codebase, I'm afraid that the same issue was present with the R terra package as in 3.12.0beta1 reported earlier. Following defensive changes in the development version of terra, its current HEAD does however pass.
Both released and development versions of terra pass with 3.12.0beta2.
I think that this means that the 3.11 branch does not have the mitigations for the multiple dimension problem.
Roger
Roger Bivand
Emeritus Professor
Norwegian School of Economics
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway
________________________________________
Sent: 15 June 2023 21:26
To: Roger Bivand
Cc: geos-devel at lists.osgeo.org; Robert Hijmans; Edzer Pebesma
Subject: Re: [geos-devel] 3.12.0beta1
> On Jun 15, 2023, at 12:08 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> Paul, will try tomorrow morning my time. Does this 3.11 contain the fix for gcc 13 - I had to switch to devel on upgrading to Fedora 38 so if that commit is also present here, it should be feasible, if not rather harder.
There are patches for gcc 13 in the head of the 3.11 branch, so hopefully will just Work.
P
> Roger
> Roger Bivand
> Emeritus Professor
