[geos-devel] 3.12.0beta1
Paul Ramsey pramsey at cleverelephant.ca
Fri Jun 16 08:13:29 PDT 2023
> On Jun 16, 2023, at 8:03 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> Using the https://github.com/libgeos/geos/tree/3.11 codebase, I'm afraid that the same issue was present with the R terra package as in 3.12.0beta1 reported earlier. Following defensive changes in the development version of terra, its current HEAD does however pass.
> Both released and development versions of terra pass with 3.12.0beta2.
> I think that this means that the 3.11 branch does not have the mitigations for the multiple dimension problem.
Well, the fix for a separate problem brings this one up to visibility. Going to have to wriggle around to find an optimum compromise.
Thanks for confirming!
P
> Roger
> Roger Bivand
> Emeritus Professor
> Norwegian School of Economics
> Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway
> ________________________________________
> From: Paul Ramsey <pramsey at cleverelephant.ca>
> Sent: 15 June 2023 21:26
> To: Roger Bivand
> Cc: geos-devel at lists.osgeo.org; Robert Hijmans; Edzer Pebesma
> Subject: Re: [geos-devel] 3.12.0beta1
>> On Jun 15, 2023, at 12:08 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>> Paul, will try tomorrow morning my time. Does this 3.11 contain the fix for gcc 13 - I had to switch to devel on upgrading to Fedora 38 so if that commit is also present here, it should be feasible, if not rather harder.
> There are patches for gcc 13 in the head of the 3.11 branch, so hopefully will just Work.
> P
>> Roger
>> Roger Bivand
>> Emeritus Professor
