[geos-devel] 3.12 release warning
Greg Troxel gdt at lexort.com
Tue Jun 20 09:29:13 PDT 2023
Sebastiaan Couwenberg <sebastic at xs4all.nl> writes:
> Warning message:
> In fun(libname, pkgname) :
>   rgeos: versions of GEOS runtime 3.12.0beta2-CAPI-1.18.0
> and GEOS at installation 3.11.1-CAPI-1.17.1differ
Also, I found that geoe does not use the just-built library when running
tests, due to inadequate RPATH/LD_LIBRARY_PATH, so if you are testing
3.12 on a system with 3.11 installed, the tests may be running 3.11
code.
