[geos-devel] 3.12 release warning
Paul Ramsey pramsey at cleverelephant.ca
Tue Jun 20 10:28:23 PDT 2023
> On Jun 20, 2023, at 9:29 AM, Greg Troxel <gdt at lexort.com> wrote:
> Sebastiaan Couwenberg <sebastic at xs4all.nl> writes:
>> Warning message:
>> In fun(libname, pkgname) :
>>  rgeos: versions of GEOS runtime 3.12.0beta2-CAPI-1.18.0
>> and GEOS at installation 3.11.1-CAPI-1.17.1differ
> Also, I found that geoe does not use the just-built library when running
> tests, due to inadequate RPATH/LD_LIBRARY_PATH, so if you are testing
> 3.12 on a system with 3.11 installed, the tests may be running 3.11
> code.
It would be helpful if this finding were qualified with the particular platform it was found on, and the steps to reproduce, since I’ve never managed to make it happen myself, and my computer is chock full of different versions of GEOS in different places.
P
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
