[geos-devel] [GEOS] #934: disable svn access from the web
GEOS geos-trac at osgeo.org
Fri Jun 30 16:33:58 PDT 2023
 Reporter:  gdt        |       Owner:  geos-devel@…
     Type:  task       |      Status:  closed
 Priority:  minor      |   Milestone:  Management
Component:  Default    |     Version:  main
 Severity:  Annoyance  |  Resolution:  fixed
 Keywords:             |
Comment (by Paul Ramsey <pramsey@…>):
 In [changeset:"e93854317dd3130644891c73579e773859a12717/git" e938543/git]:
 {{{#!CommitTicketReference repository="git"
 revision="e93854317dd3130644891c73579e773859a12717"
 Explicitly set endianness for some tests so that output matches expected.
 Closes #934
Ticket URL: <https://trac.osgeo.org/geos/ticket/934#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
