[geos-devel] [GEOS] #934: disable svn access from the web
GEOS geos-trac at osgeo.org
Fri Jun 30 16:34:06 PDT 2023
 Reporter:  gdt        |       Owner:  geos-devel@…
     Type:  task       |      Status:  closed
 Priority:  minor      |   Milestone:  Management
Component:  Default    |     Version:  main
 Severity:  Annoyance  |  Resolution:  fixed
 Keywords:             |
Comment (by Paul Ramsey <pramsey@…>):
 In [changeset:"6bc91ff0f985abb96e44f1c8ef9cf010d9d2006c/git" 6bc91ff/git]:
 {{{#!CommitTicketReference repository="git"
 revision="6bc91ff0f985abb96e44f1c8ef9cf010d9d2006c"
 Explicitly set endianness for some tests so that output matches expected.
 Closes #934
Ticket URL: <https://trac.osgeo.org/geos/ticket/934#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
