[geos-devel] 3.10.5 and 3.11.2 released
Paul Ramsey
pramsey at cleverelephant.ca
Fri Mar 17 08:13:06 PDT 2023
This is expected, they came along for the backport of
- Fix handling of odd cases in PolygonHoleJoiner (JTS-946, Paul Ramsey, Martin Davis)
P
> On Mar 17, 2023, at 6:23 AM, Brian M Hamlin <maplabs at light42.com> wrote:
> I confirm that 3.11.3 build shows two new header files, called PolygonNoder.h and PolygonNodeTopology.h
> --Brian M Hamlin / MAPLABS / OSGeoLive PSC
> On 3/17/23 04:51, Greg Troxel wrote:
>> In 3.11.2 vs 3.11.1 I find new files installed
>> ERROR: The following files are in /tmp/work/geography/geos/work/.destdir/usr/pkg but not in the PLIST:
>> ERROR: /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/algorithm/PolygonNodeTopology.h
>> ERROR: /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/triangulate/polygon/PolygonNoder.h
>> and do not immediately see adding new interfaces in NEWS, so I wanted to
>> check that this is intended/correct before I push the update to pkgsrc.
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geos-devel
