[geos-devel] 3.10.5 and 3.11.2 released
Brian M Hamlin maplabs at light42.com
Fri Mar 17 06:23:02 PDT 2023
I  confirm that 3.11.3 build shows two new header files, called
PolygonNoder.h and PolygonNodeTopology.h
   --Brian M Hamlin    /  MAPLABS  /  OSGeoLive PSC
On 3/17/23 04:51, Greg Troxel wrote:
> In 3.11.2 vs 3.11.1 I find new files installed
> ERROR: The following files are in /tmp/work/geography/geos/work/.destdir/usr/pkg but not in the PLIST:
> ERROR:         /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/algorithm/PolygonNodeTopology.h
> ERROR:         /tmp/work/geography/geos/work/.destdir/usr/pkg/include/geos/triangulate/polygon/PolygonNoder.h
> and do not immediately see adding new interfaces in NEWS, so I wanted to
> check that this is intended/correct before I push the update to pkgsrc.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
