[geos-devel] [postgis-devel] MacOS DYLD Fix
Greg Troxel
gdt at lexort.com
Sat Nov 11 06:33:48 PST 2023
Paul Ramsey via postgis-devel <postgis-devel at lists.osgeo.org> writes:
>> On Nov 10, 2023, at 3:46 PM, Regina Obe <lr at pcorp.us> wrote:
>> This isn’t an issue with other projects besides PostGIS that use GEOS?
>> Perhaps related, how much trouble would it be to get PostGIS to use pkgconfig for GEOS. I see that GEOS does ship pkgconfig files.
> We could probably do it on a going-forward basis, but per usual we’d
> end up with all the old code *plus* the pkgconfig code, so it wouldn’t
> really “clean up” anything. There are autoconf macros already in
> configure.ac doing pkgconfig stuff on other deps, so not too too hard
> of an add.
We need the old code because postgis allows geos that is too old for
pkgconfig? I lean to use pkgconfig if it exists and then drop support
for not-pkgconfig when geos that doesn't do it ages out.
>> It’s always annoying when I try to do it that I have to explicitly
>> specify the geos-config file in PostGIS when in other cases, we can
>> read the pkg-config and have in fact standardized on that for other
>> dependencies we use.
>> I’ve added PostGIS dev to this since well we seem to be talking about PostGIS now.
> I’m honestly at a bit of a loss as to whether installing with an rpath
> and expecting linking software to set an appropriate search path is
> the right thing, or locking in a fixed installation location is the
> right thing. Certainly the latter results in less nonsense in the
> postgis build. But it broke proj, which had some tests that expected
> to be able to manually move an installation post-install.
Software that searches for a library should (again speaking normally not
macOS-ish), should after finding the lib in prefix
add -I$prefix/include to CPPFLAGS
add
-L$prefix/lib -Wl,-R$prefix/lib -lfoo
to LDFLAGS/LDADD
or however R, rpath, should be.
this is basically from pkgconfig's misnamed flags:
$ pkg-config --cflags geos; pkg-config --libs geos
-I/usr/pkg/include
-L/usr/pkg/lib -lgeos_c
Installed pkgconfig files often get this wrong and omit the rpath.
That's ok to do if $prefix/lib is in the system's default search path,
which it isn't in this case.
glib, in contrast, produces:
$ pkg-config --cflags glib-2.0; pkg-config --libs glib-2.0
-I/usr/pkg/include/glib-2.0 -I/usr/pkg/lib/glib-2.0/include -I/usr/pkg/include
-Wl,-R/usr/pkg/lib -L/usr/pkg/lib -lglib-2.0 -lintl
For pkgsrc, this missing -R is not in practice a problem in almost all
cases because almost everything is in /usr/pkg (or /opt/pkg, but the
same place) and there is an overall -R for that. When things are in a
subprefix (for parallel installation of multiple versions), it matters
more.
For Debian and most GNU/Linux distributions, everything is in /usr and
thus in the default path.
Running objdump -x on /usr/pkg/lib/libgeos_c.so:
NEEDED libgeos.so.3.12.0
NEEDED libstdc++.so.9
NEEDED libm.so.0
NEEDED libgcc_s.so.1
NEEDED libc.so.12
SONAME libgeos_c.so.1
RPATH /usr/pkg/lib
and that seems right. That RPATH really is needed formally as one
cannot assume that the program linking in geos_c has RPATH, only that it
found geos_c.
It sounds like the issue is that macOS does things differently and we
weren't ending up with the equivalent of RPATH set on macOS builds?
