3.13.0beta1 ?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Aug 16 06:39:51 PDT 2024
On 2024-08-16 8:15 a.m., Mike Taves wrote:
> On Fri, 16 Aug 2024 at 14:30, Regina Obe <lr at pcorp.us> wrote:
>> I assume that GEOS there is meant to be GDAL?
>> What does upgrading CMake buy us.
> Oh right, yes GDAL. It mostly buys a fix for MSVC Ninja build
> messages, which wasn't fixed to my knowledge.
>> I'm still hesitant to up the CMake version just for the sake of upping the CMake version especially so late in the cycle of GEOS 3.13 development.
>> If we had done this early own, I would not have an issue.
> Understandable, as it is the 11th hour. I have a PR to consider for
> GEOS 3.13, otherwise it can wait to be merged for the next dev phase:
> https://github.com/libgeos/geos/pull/1143
Thanks Mike.
Regarding trying to get changes made for packagers, as you saw my same
change rejected here in the previous pull request, I just instead have
been making that change locally - it avoids the questioning, and helps
the users downstream, without the firestorm. :)
Enjoy your weekend,
-jeff
