3.14 Release Calendar
Regina Obe lr at pcorp.us
Mon Aug 11 07:36:02 PDT 2025
Dan,
Is it a lot of work to push in the GEOSSubdivideByGrid.  If it delays you then I would say pull it out.
If it’s just concern about durability, but api is not going to change, I’d leave it in as any issues with the logic can be fixed in micro versions.
Sent: Monday, August 11, 2025 10:23 AM
To: Paul Ramsey <pramsey at cleverelephant.ca>
Cc: GEOS Development List <geos-devel at lists.osgeo.org>
Subject: Re: 3.14 Release Calendar
I could pull GEOSGridIntersectionFractions (well-tested with ~7 years of use) into a separate PR for 3.14, and leave GEOSSubdivideByGrid (more experimental) for the next release?
Dan
On Fri, Aug 8, 2025 at 6:59 PM Paul Ramsey <pramsey at cleverelephant.ca <mailto:pramsey at cleverelephant.ca> > wrote:
I would like to release 3.14.0rc1 next week.
Our packagers have given the cautious green light and I am not hearing
that remaining PRs are going to land shortly.
I think we should consider an early 3.15 as necessary to bring in any
features that only just barely miss this cycle and we want out in the
wild.
Thoughts?
P
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20250811/e9e208a9/attachment.htm>
