3.14 Release Calendar
Daniel Baston dbaston at gmail.com
Mon Aug 11 07:48:46 PDT 2025
I'm in the "just need to handle one more edge case" phase, which can go on
for some time, or not.
Dan
On Mon, Aug 11, 2025 at 10:36 AM Regina Obe <lr at pcorp.us> wrote:
> Dan,
> Is it a lot of work to push in the GEOSSubdivideByGrid.  If it delays you
> then I would say pull it out.
> If it’s just concern about durability, but api is not going to change, I’d
> leave it in as any issues with the logic can be fixed in micro versions.
> *From:* Daniel Baston <dbaston at gmail.com>
> *Sent:* Monday, August 11, 2025 10:23 AM
> *To:* Paul Ramsey <pramsey at cleverelephant.ca>
> *Cc:* GEOS Development List <geos-devel at lists.osgeo.org>
> *Subject:* Re: 3.14 Release Calendar
> I could pull GEOSGridIntersectionFractions (well-tested with ~7 years of
> use) into a separate PR for 3.14, and leave GEOSSubdivideByGrid (more
> experimental) for the next release?
> Dan
> On Fri, Aug 8, 2025 at 6:59 PM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> I would like to release 3.14.0rc1 next week.
> Our packagers have given the cautious green light and I am not hearing
> that remaining PRs are going to land shortly.
> I think we should consider an early 3.15 as necessary to bring in any
> features that only just barely miss this cycle and we want out in the
> wild.
> Thoughts?
> P
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20250811/45a5e42e/attachment.htm>
